AI_DOME command
Creates a 3D polygon mesh in the shape of the upper half of a sphere.
Icon:
Creates a 3D polygon mesh in the shape of the upper half of a sphere. Choose from a combination of options including center, radius, diameter and number of segments.
- Center
- Diameter
- Radius
- Top to bottom segments
- Segments around dome
Methods to create a dome
There is one method to begin creating a dome:
- Center of dome
- Center of dome
- Begin creating a dome by specifying the center of the dome’s open end then:
- Radius of dome
- Specify the radius of the dome.
- Number of segments around dome
- Specify the number of isolines, perpendicular to the xy-plane, used to simulate the dome’s curved surface. The default is 16.
- Number of top-to-bottom segments
- Specify the number of isolines, parallel to the xy-plane, used to simulate the dome’s curved surface. The default is 8.
Options within the AI_DOME command
After you begin creating a dome, the following option may be available:
- Diameter
- Specify the diameter of the dome.
