AI_SPHERE command
Creates a 3D polygon mesh in the shape of a sphere.
Icon:
Creates a 3D polygon mesh in the shape of a sphere. Choose from a combination of options including center, radius, diameter, and number of segments.
- Center
- Diameter
- Radius
- Latitudinal segments
- Longitudinal segments
Methods to create a sphere
There is one method to begin creating a sphere:
- Center of sphere
- Center of sphere
- Begin creating a sphere by specifying the center then:
- Set radius of sphere
- Specify the radius of the sphere.
- Number of longitudinal segments
- Specify the number of isolines, perpendicular to the xy-plane, used to simulate the sphere’s curved surface. The default is 16.
- Number of latitudinal segments
- Specify the number of isolines, parallel to the xy-plane, used to simulate the sphere’s curved surface. The default is 16.
Options within the AI_SPHERE command
After you begin creating a sphere, the following option may be available:
- Diameter
- Specify the diameter of the sphere.
