ALIGN command
Moves, rotates, and scales entities to align with specified points.
Icon:
Alias: AL
Moves, rotates and scales entities in 2D or 3D space by specifying a set of alignment points.
Options within the command
- Select entities
- Selects entities that are to be aligned.
- Specify first source point
- Specifies the source alignment point.
- Specify first destination point
- Specifies the destination alignment point.
- Specify second source point
- Specifies the second source alignment point.
- Specify second destination point
- Specifies the matching destination point.
- Scale objects based on alignment points
- Allows you to scale the source object.Note: Scaling is only available when aligning entities using two pairs of points.
- Yes
- Scales objects relative to the picked points.
- No
- Does not scale objects.
- Specify third source point
- Specifies the source point for 3D alignment.
- Specify third destination point
