ALIGNMENTEDIT command
Edits an alignment.
Icon:
Method
Select a Horizontal or Vertical alignment to edit.
Options within the command for Horizontal alignment
- Continue with Pi
- Allows you to continue the Horizontal alignment.Note: This option works only if the last element is fixed line.
- Delete Element
- Allows you to delete alignment elements.
- Add Pi
- Adds a Pi Point to the alignment.
- Remove Pi
- Removes a Pi point.
- change Tin surface
- Changes the Tin surface of the Horizontal alignment by adding additional TIN surface.
- Add Station equation
- Allows you to add station equation.
- Remove Station equation
- Allows you to remove station equation by specifying the index.
Options within the command for Vertical alignment
- Add Pvi
- Adds a Pvi point to the alignment.
- Remove Pvi
- Removes a PVI point.
- Changes the Tin surface of the Vertical alignment by adding additional TIN surface.
