AMNOTE command
Draws a leader note and attaches it to an entity.
Icon:
Method
Select the object to attach the leader note and specify the points for its location. Next, add the text note in the Contents field of the Properties panel.
- There are two use cases to activate the mechanical entities:
- When creating a new drawing that contains mechanical entities:
- Set the LOADMECHANICAL2D system variable to ON (1).
- Start a new drawing using a Mechanical2d template.
- When opening a drawing that contains mechanical entities:
- Open an existent ACM drawing and start special symbols creation.
Note: These dimensions are compatible with the legacy AutoCAD® Mechanical application.
Note: The dimensions will be added to the AM_5 layer.
Note: After opening a drawing that contains mechanical entities, filling other drawings with mechanical-related data will be done on-demand in contrast to previous versions. It will be possible when a user copies the mechanical-related entities to the vanilla drawing. In case of copying entities that are not related to the mechanical data, a vanilla drawing will not be filled with mechanical data.
Note: When you open a drawing that contains mechanical entities, but the LOADMECHANICAL2D system variable is OFF, a warning bubble is displayed at the status bar that describes the situation and provides a hyperlink to immediately enable and load the mechanical 2d modules.
After creating the leading note with the AMNOTE command, their properties can be configured in the Properties panel:
Symbol
- Drafting standard
- Displays the drafting standard.
- Standard revision
- Displays the standard revision.
- Scale
- Sets the note scale.
- Flip Symbol
- Switches between Right and Left aligned text from the ending of the extension line.
- Show reference line
- Switches between show (ON) and hidden (OFF) the reference line.
- Text justification
- Specifies the location of the text regarding the extension line.
- Leader justification
- Sets the leader justification type.
Requirements
- Content
- After creating an AMNOTE, add the content of the note.
Leader
- Primary arrowhead
- Sets the leader style.
