AMPARTLIST command
Inserts in the drawing area a parts list, according to an indicated BOM.
Icon:
Note: This command only works for drawings that contain mechanical entities. To set the environment for BricsCAD Mechanical drawings, see the Overview of 2D Mechanical Drawings commands article.
Method
Note: The Part List is added to the AM_5 layer.
Specify according to which BOM you will create the parts list and place it in the drawing area. The Parts List dialog box opens to configure appearance and content of the table.
Note: Multiple Parts Lists from the same BOM containing different information are allowed.
Options within the command
- Main
- Selects the main BOM for the part list.Note: The Main BOM table is current by default. The last used BOM table in the command is set as current.
- Lists all available BOM in the command panel.
