AMPOWERDIM_CHAM command
Creates dimensions for chamfers.
BricsCAD Mechanical
Icon:
Note: This command only works for drawings that contain mechanical entities. To set the environment for BricsCAD Mechanical drawings, see the Overview of 2D Mechanical Drawings commands article.
Automatically creates dimensions for chamfers, which consist of two linear dimensions aligned with the adjacent lines of the chamfer.
This command is a shortcut to the chaMfer option of the PDIM command.
Method
Select the chamfer line and the two adjacent lines.
