AMSIMPLEWELD command
Creates caterpillars and side weld annotations.
BricsCAD Mechanical
Icon:
Note: This command only works for drawings that contain mechanical entities. To set the environment for BricsCAD® Mechanical drawings, see the Overview of 2D Mechanical Drawings commands article.
Options within the command
Front
Creates a front view fillet or single -V butt welds (caterpillars) along a curve (line, polyline, arc, ellipse) between two specified points.
Note: Caterpillars are created as block references in the layout.
Alignment
Defines the type of the caterpillars weld.
Left
Adds a partial caterpillar and places it on the left of the curve.
Center
Adds a full caterpillar and centers it on the curve.
Right
Adds a partial caterpillar and places it on the right of the curve.
Note: If the HOTKEYASSISTANT system variable is ON, the Hotkey Assistant widget displays. Repeatedly press the Ctrl key to cycle the above various options.
Width
Defines the weld width.
Note:
  • For a partial caterpillar, the weld width is the distance between the endpoint of the beam and the selected edge.
  • For a full caterpillar, the weld width is the distance between the two endpoints of the beam.
Step
Defines the bead pitch.
switch Orientation
Toggles the bead orientation.
switch Direction
Toggles the bead direction.
Full
Creates the front weld symbol along the entire selected curve.
Side
Creates a side view seam or single -V butt welds with the specified Leg width and rotation angle.
Fillet
Creates a side view for a fillet weld.
single - V butt
Creates a side view for a single - V butt weld.
Note: If the HOTKEYASSISTANT system variable is ON, the Hotkey Assistant widget displays. Repeatedly press the Ctrl key to cycle through the above options.
change leg Width
Defines another value for the leg width.
