AMWELDSYM command
Creates a welding symbol in the drawing space.
Icon:
Note: This command only works for drawings that contain mechanical entities. To set the environment for BricsCAD Mechanical drawings, see the Overview of 2D Mechanical Drawings commands article.
Method
Note: The welding symbol is added to the AM_5 layer.
Select the entity to attach the welding symbol and specify the points for its location. The Weld Symbol dialog box opens, where you can customize the weld symbol parameters.
Note: To place welding symbols in the drawing views (Paper space), use BMWELDSYMRETRIEVE command.
When you double-click a welding symbol, the Weld Symbol dialog box opens, allowing you to change its parameters.
Also, you can change the welding symbol's properties from the Properties panel:
