APPLYAUTOMAPPING command
Automatically applies the active auto mapping set of codes to the selected civil points.
Method
Select civil points in the drawing to assign them properties from the active auto mapping codes.
The auto mapping codes are generated in the Edit Auto Mapping Set dialog box.
Options within the command
- press Enter key to select all points
- Selects all civil points in the drawing.
