-BIMPYTHON command
-BIMPYTHON command
Allows Python Scripting and Querying of a BIM model via Command line.
BricsCAD BIM
Method
The command opens the Select Python script dialog box. Select a PY file, then click Open to run the script.
Note: Python version shipped with BricsCAD is increased to 3.12.
Related commands
  • BIMPYTHON command
  • SCRIPT command
  • SETTINGS command
Related information
  • Generic Open file dialog box
  • Settings dialog box (new)
  • Using Python scripts
