-BMINSERT command
Inserts sheet metal form features and components in the current drawing.
Note: The BMINSERT command is being phased out and will not be available in BricsCAD® V27. When running the command, the following dialog box appears:
Inserts sheet metal form features, mechanical blocks and BIM components in the current drawing.
Note: This command inserts a RFA file as a BIM component.
This command operates at the Command line. Enter the path of the file to be inserted and choose one of the options. For more details about the options, see the BMINSERT command article.
