BMFORM command
Creates a new mechanical block, and inserts it into the current drawing.
Icon:
Creates a new mechanical block as an internal reference in the current drawing. The selected solid(s) are removed from the current drawing.
Note: If necessary, run the BMMECH command first to initialize the mechanical structure in the current drawing.
Options within the command
- Local
Creates a new mechanical block and inserts it as a block reference into the current drawing.
Note: Use BEDIT command to edit block definition.
- External
- Creates a new drawing which contains the selected solid(s) and can be saved with the Save Drawing As dialog box. The selected solid(s) are removed from the current drawing. The new drawing is inserted as an external reference in the current drawing.
- Template settings
- Opens the Settings dialog box at the BMFORMTEMPLATEPATH system variable to choose a template file.
