BIMATTACHCOMPOSITION command
Attaches a BIM composition to solids.
Icon:
Method
This command offers 3 methods to attach the compositions.
- Enter the composition name
- Compositions dialog box
- Select an entity
Options within the command
- Dialog
- Opens the Compositions dialog box.
For more information about the dialog box, see the article BLCOMPOSITIONS command.
- Entity
- Applies the composition of an existing solid. First you select the entities to copy the composition from, next you select one or multiple entities to attach the composition to.
- deTach
- Allows to detach a composition, while keeping the BIM classification, as different from the Unclassify option of the BIMCLASSIFY command, which removes all BIM data.
