BIMCOLLECTDETAILS command
Collects all tagged details from the active sheet and inserts layouts of these details on the sheet.
Method
After it collects all tagged details from the active sheet, it inserts layouts of these details on the sheet. You have to specify the base and second insertion points for the layout. The inserted layout will hold a pointer to the detail source. This additional information allows BIMCHECKDETAILS command to list and interact with the inserted layouts for the project details.
Note: This command is available only in a sheet.
