BIMREASSOCIATE command
Automatically re-associates invalid Tags and Dimensions to the underlying geometry.
Select a BIM section viewport in order to automatically re-assign invalid Tags and Dimensions to the underlying geometry.
Note:
- The BIM Associativity property indicates whether a tag is associated.
- The BIM Associative coloring property visualizes an unassociated tag in red, if true. It doesn't change the color property. After re-associating, BIM tags are displayed in their layer color.
