Converts identical set of entities (2D or 3D) to block references.
Icon:
Searches the drawing for identical sets of entities (2D or 3D) and replaces them with block
references.
Method
There are four methods to use BLOCKIFY command:
Convert 2D and 3D entities to blocks.
Convert equally shaped solids to blocks.
Find collections of existing blocks.
Match geometry to existing block definitions.
Note: To replace block patterns by arrays of entities, use the ARRAYDETECT
command.
If a selection set is active when launching the command, the current settings of the BLOCKIFYMODE
and BLOCKIFYTOLERANCE system variables are used for running the command.
If no selection set is active when launching the command, the Command Context panel
opens displaying the Settings options. You can modify the
BLOCKIFYMODE and BLOCKIFYTOLERANCE system variables settings through the options
displayed in the tab.
Blockify settings
Shows all the settings available in BLOCKIFYMODE system variable with their current state and
lets you modify them:
Search entire drawing
Use the entire drawing as search space.
Use default insertion point
Let the application automatically assign the insertion point when creating new block
definitions.
Use default block name
Use the default block name as specified in settings.
Compare geometry only
Ignore color, layer, line type, scale, weight and thickness, transparency, plot style and
material properties when comparing entities.
Convert unique solids
Convert solids to blocks when they occur only once.
Show preview
View the matches in the drawing and select the matches you want to replace with block
references.
Tolerance
Allows you to modify the current value of the BLOCKIFYTOLERANCE system variable that specifies
the relative tolerance for determining whether two entities are equal.
Options within the command
match Equal solids
Searches the drawing (or the selection) for equally shaped solids and
replaces them with block references of the newly created block
definitions. In case a solid matches an existing block definition, the
replacing block reference points to that block definition.
Note: This option is not available in the Lite license level.
Select the search space or choose the entire drawing as a search space.
Specify block name or <ENTER to use default name>
Specify a block name or use the default name. If you choose to use the default name, block
definitions with names like Block, Block1, Block2 etc. are created.
Note: If BLOCKIFY is used on BIM entities, it checks the BIM Name property of
all equal-shaped BIM classified solids and tries to find the longest common substring to use it as
the name of the block definitions.
The match Equal solids option opens the Command
Context panel displaying the Matches settings.
Select the groups to be replaced by ticking the corresponding boxes.
Click on the individual green check marks/red cross signs in the model
space to further select/deselect the entities you want to be replaced
with block references.
find Collections
Searches for identical sets of block references and lets you choose
the ones to create new nested block definitions from. The
collections within the selected sets are then replaced with block
references of these definitions.
The find Collections option opens the Command
Context panel displaying the Options,
Collections and
Detailssettings.
Note: With a large number of input entities, calculating all
possible collections can take a long time. Press the Esc key to
cancel the calculation at any time, and choose from the
collections found so far.
Maximum gap
Increases the allowed gap between entities to find a more complex collection.
For example: If a drawing contains multiple block references of desks and chairs, you can find a collection of both elements by setting the maximum gap between a desk and a chair.
Recalculate
Recalculates the collections based on the new maximum gap.
Collections
Displays the found collection sets. Select the collection set you want to create the nested block reference from.
Note:
A message is displayed if the selected set contains overlapping collections. Overlapping collections are collections that have at least one solid in common. Select which of the overlapping collections to remove so you can create the new block.
The overlapping collections are highlighted if the Highlight overlapping collections option is ticked.
Details
Tick the Show option to highlight one collection at a time within the collection set and cycle through by using the arrows. Use the zoom in button to extend the view to the highlighted collection.
Remove
Removes the current highlighted collection from the collection set.
Reset
Resets to the initially found collections in the collection set, by re-adding any collections that were removed.
Note: After creating a block reference, the collections sets are recalculated, taking into account the newly created block reference. Thus some of the collection sets configurations previously found are no longer available.
match existing Blocks
Searches the drawing (or the selection) for geometry matching existing
block definitions. The match existing Blocks
option opens the Command Context panel displaying the
Matches settings. Select the groups to be
replaced with block references of those definitions by ticking the
corresponding boxes. Further select the entities to be replaced by
clicking the individual green check marks/red cross signs in the model
space.
selection options (?)
Lets you choose one of the listed methods to add entities to the selection set.
BLOCKIFY command - BricsCAD Lite & Pro | Bricsys Help Center
