BMEXPLODECONFIG command
Assigns preferable directions for entities during automatic generation of exploded views.
BricsCAD Mechanical
Automatically converts directions defined in WCS to local directions of selected entities during generation of exploded views.
Method
Select entities which will use the preferable direction for exploded view, then set the direction.
Options within the command
Set
Selects entities to set preferable direction for disassembly.
Root part
Selects only root part.
Entire model
Selects entire model.
Remove
Selects entities to remove from preferable direction for disassembly.
Select the direction
Selects the direction for selected entities which will be follow on exploded views.
Select axial entity
Allows you to select an existing axial entity.
2Points
Selects two points to define the direction.
Xaxis
Selects the X axis as direction.
Yaxis
Selects the Y axis as direction.
Zaxis
Selects the Z axis as direction.
