BMTRAILINGLINES command
Creates all necessary trailing lines for selected parts.
Creates all necessary trailing lines by selecting entities.
When you select two parts and a 3D polyline, a custom trailing line based on the 3D polyline will be generated. This trailing line will be visible in the Mechanical Browser.
Note: An exploded view needs to be selected and open for editing before the command can be run.
Options within the command
- use Origin points
- Switches the mode used to choose the reference point for parts to the origin (insertion point) of the component.
- use Center points
- Switches the mode used to choose the reference point for parts to the center point of the bounding box of the component.
- Entire model
- Selects the entire model and starts the processing.
- for current Step
- Generates a trailing line for the current step, which means it will be shown only for this step.
Note: By default, trailing lines are generated for the current step.
