BMUPDATE command
Reloads all referenced components from external files and updates BOM tables.
Icon:
The command:
- Reloads referenced components from external files (BmInsert).
- Rebuilds component based features, sheet metal form features and BIM windows/doors components (see BC_SUBTRACT layer, Form Features, BmInsert).
- Updates the Bill Of Material (BmBom).
- Regenerates drawing views produced out of 3D model (ViewBase).
Note: If the BMAUTOUPDATE system variable is ON, external assembly components are reloaded on opening the file.
Options within the command
- MOde
- Defines the new placement face.
- Automatic
- The placement face for the feature is detected automatically.
- Manual
- Select a new placement face manually.
- Entire model
- Updates the entire model.
