BMUNMECH command
Converts mechanical blocks.
The command converts the current mechanical blocks into a plain drawing.
Note: The command applies to drawings that are a mechanical blocks only.
Options within the command
- Yes
- Removes the mechanical structure from the drawing, by turning it into a plain drawing.
- No
- Aborts the command.
