INSERT command
Opens the Insert block dialog box.
Icon:
Alias: DDINSERT, I
Opens the Insert block dialog box to insert a block instance from a block definition. The block definition may exist in the current drawing or as an external DWG file.
- Name
- Browse
- Path
- Insert external reference
- Insertion Point
- Scale
- Rotation
- Block unit
- Advanced settings
Name
Specifies the name of the block, whose definition exists in the drawing, or is a DWG or DXF file on the computer or network.
Browse
Selects a DWG or DXF file from your computer or network. Opens the Select Drawing File dialog box.
Path
Displays the path to the block, if the block was opened from a DWG or DXF file.
Toggles whether the block is inserted as a local or external reference.
Insertion Point
Specifies the insertion point of the block in the drawing.
Scale
Scales the block:
- X, Y, Z: Defines the scaling of the block:
- X specifies the scale factor along the x axis. Enter a negative value to mirror the block about the y axis.
- Y specifies the scale factor along the y axis. Enter a negative value to mirror the block about the x axis.
- Z specifies the scale factor along the z axis.
- Uniform Scale: Toggles whether the same scale factor is used for all axes.
- Values larger than 1 make the block larger.
- 1 inserts the block at actual size.
- Values smaller than 1 make the block smaller.
- Values less than zero flip the block, like mirroring it.
Rotation
Specifies the rotation angle of the block about its insertion point, starting with the x-axis as 0 degrees.
Block unit
Controls the automatic scaling of the block with respect to the INSUNITS system variable of the current drawing.
Advanced settings
Displays the available advanced settings.
- Show dynamic dimensions
- Toggles whether to show in the drawing dynamic dimensions.
- Insert Sheet Metal Form Feature
- Toggles whether to insert sheet metal form feature. The Insert Sheet Metal Form Feature option is available only if the Model Space contains SM flanges.
- Insert BIM Component
- Toggles whether to insert BIM Components.Note: The Insert BIM Component option is available only if the Model Space contains BIM entities.
- Use reference curves for insert
- Toggles whether a reference curve is used for insert.
- Explode
- Toggles whether to insert the exploded block.
- Insert as anchor
- Anchors a block to a face of a solid. This anchor links the block to the face. The block will stay on the face when the host solid is moved or edited.
Options within the command
When the option in the Insert Block dialog box is enabled, the following options appear in the Command line.
- Edit inserted entity
- Enables you to change the parameter expressions for the inserted entity. Continue editing individual parameters until you press FINISH to end the option. This option is also available in the Hot Key Assistant.
- Enter parameter name
- Specifies the name of the parameter.
- Enter expression
- Specifies the expression for the parameter.
- FINISH
- Finishes the editing of individual parameters.
- SMART insert
- Enables you to connect a Piping standard part to an existing Piping standard part. It automatically creates appropriate 3D constraints between the two parts and copies expressions for the parameters of the existing part to the new part. This option is also available in the Hot Key Assistant.
- Rotate component
- Allows you to change the rotation angle for the inserted entity.
- set Base point
- Allows you to change the base point for the inserted entity.Note: By default is <0,0,0>.
- Name
- Allows you to change the component insert name.
- insertion Type
- Specifies the insertion type.
- Flip
- Allows you to flip the direction for the inserted entity.
- Change target 3d solids
- Allows you to apply the inserted entity to existing 3D solids in the current drawing.
- Select target 3D solids
- Selects the target 3D solids.
- cleaR
- Clears the selection set to ensure no solids are affected by the inserted entity.
- Select all affected 3d solids
- All solids intersecting or touching solids in the BC_SUBTRACT and BC_UNITE layers of the inserted entity are affected.
- Multiple
- Allows you to you to insert multiple copies of the same entity by specifying an insertion point for each instance.Note: Continue inserting entities until you press Enter to end the command.
- Array
- Allows you to create an associative array of the inserted entity by specifying the base point, distance between columns, distance between rows and end point of the array.
- Direction
- Allows you to select an existing axial entity to define the direction.
- 2Points
- Selects two points to define the direction.
- Zaxis
- Selects the Z axis as direction.
- Object
- Allows you to select an axial entity.
- Last
- Uses the previous axis.
- View
- Allows you to specify a point on view direction.
- Xaxis
- Selects the X axis as direction.
- Yaxis
- Selects the Y axis as direction.
- Single row
- Distributes entity copies into a single row.
- Rectangular
- Distributes entity copies into any number of rows.
- Columns
- Specifies the number of the columns.
- Rows
- Specifies the number of the rows.
- Placement
- Sets the distance between the entities.
- Accept
- Accepts the resulting array.
- Scale
- Allows you to scale the inserted block.
- X scale
- Allows you to scale the inserted block on X axis.
- Y scale
- Allows you to scale the inserted block on Y axis.
- X scale
- Allows you to scale the inserted block on Z axis.
