BOX command
Creates a 3D solid in the shape of a box.
Note: In BricsCAD Lite, which doesn’t support 3D Solids, the BOX command launches the AI_BOX command.
Icon:
Create a 3D solid in the shape of a rectangular or square box. Choose from a combination of options including corner, center, length, width, height, and cube.
- Center of box
- Corner of box
- Opposite corner
- Height
- Width
- Length
Method
This command has 2 methods to begin creating a box:
- Set corner of box
- Center
Options within the command
- Set corner of box
- Allows you to specify a corner for the base of the box.
- Set opposite corner
- Allows you to specify the opposite corner for the base of the box to apply both the length and width. The box is created parallel to the X and Y axes.
- Height of box
- Specifies the height of the box.
- Center
- Allows you to begin creating a box by specifying the center of the box.
- Cube
- Allows you to specify a single distance to use for the length, width, and height of the box.
- Length of side
- Allows you to specify the length of the side of the box.
- Width of box
- Specifies the width of the box.
- 2Point
- Specifies the height of the box by picking any two points.
