CYLINDER command
Creates a 3D solid in the shape of a cylinder.
Note: In BricsCAD Lite, which doesn’t support 3D solids, the CYLINDER command launches the AI_CYLINDER command.
Alias: CYL
Creates a 3D solid in the shape of a circular or elliptical cylinder. Choose from a combination of options including center, radius, diameter, 3 point, 2 point, tangents, axis endpoints, and height.
- Center
- Diameter
- Radius
- Height
Method
This command has 5 methods to begin creating a cylinder:
- Center point
- 3 Point
- 2 Point
- Tangent tangent radius
- Elliptical
Options within the command
- Select center point
- Allows you to begin creating a circular cylinder by specifying the center of the base.
- Radius of base of cylinder
- Allows you to specify the radius of the cylinder’s base.
- Diameter
- Allows you to specify the diameter of the cylinder’s base.
- 3Point
- Allows you to begin creating a circular cylinder by specifying three points on the circumference of its base.
- First point
- Specifies the first point on the circumference.
- Second point
- Specifies the second point on the circumference.
- Third point
- Specifies the third point on the circumference.
- Point 1
- Point 2
- Point 3
- Height
- 2Point
- Allows you to begin creating a circular cylinder by specifying two points on the circumference of its base
- First end of diameter
- Specifies the first point on the diameter.
- Second end of diameter
- Specifies the second point on the diameter.
Note: The two points define the diameter of the base.
- Point 1
- Point 2
- Diameter
- Height
- Tangent-tangent-radius
- Allows you to begin creating a cylinder by selecting tangent points on the first and second entity, and the radius of the circle.
- Specify point on object for first tangent
- Allows you to select a tangent point on the first entity.
- Specify point on object for second tangent
- Allow you to select a tangent point on the second entity.
- Radius of circle
- Allows you to specify a valid radius for the base.Note: If you specify a radius that is not possible with the selected tangents, you are prompted to specify the tangents and radius again.
- Tangent point 1
- Tangent point 2
- Radius
- Height
- Elliptical
- Allows you to begin creating an elliptical cylinder by specifying three ends of the ellipse axis.
- Set first end of ellipse
- Specifies the first end of ellipse axis.
- Second end of ellipse
- Specifies the second end of the ellipse axis.
- Other end of ellipse
- Specifies the radius of the other ellipse axis.
- Center
- First axis
- Second axis
- Height
- Specify height
- Allows you to specify the height of the cylinder.
- 2Point
- Specifies the height of the cylinder as the distance between any two points.
- Axis endpoint
- Specifies the axis endpoint to define the height and orientation of the cylinder in 3D space. The center of the base is used as the other axis endpoint.
