-COLOR command
Sets the current working color, through the Command line.
Alias: -COL, -COLOUR
Methods
Enter the name, number, or RGB value of a color:
- Specify a color name: Red, Yellow, Green, Cyan, Blue, Magenta, White, ByLayer, or ByBlock.
- Specify a number from 0 to 256, which represents the Index Color.
- Specify a value for each of red, green, and blue, which represents the True Color. The range is from 0 to 255. For example, white is 255,255,255 and gray is 128,128,128.
- Specify a color book name.
