CIVILDWGEXPORT command
Exports BricsCAD® Civil entities as native CAD entities.
Icon:
Opens the Save Drawing As dialog box which allows you to export Civil entities as native CAD entities in a new drawing. You can flatten all the entities to zero elevation while keeping the annotation of spot elevation or contour labels with the correct representation.
Options within the command
Flatten entities
Allows you to flatten all entities.
Yes
Flattens all the entities to zero elevation while keeping the annotation of spot elevation or contour labels in the correct representation.
No
Does not flatten the entities.
