account
translation
Bricsys Help Center
CLEANSCREENOFF command
Displays user interface elements that were hidden by the CLEANSCREENON command.
Note: Do not use the numeric keypad. On AZERTY keyboards: do not press the Shift key when hitting the number key.
Related commands
  • CLEANSCREENON command
  • COMMANDLINE command
  • COMMANDLINEHIDE command
  • RIBBON command
  • RIBBONCLOSE command
  • STATBAR command
Related variables
  • CLEANSCREENOPTIONS system variable
  • CLEANSCREENSTATE system variable
Related information
  • The clean screen mode
© 2026 Bricsys NV. All rights reserved.Privacy statement -Terms of use -Cookie statement
