COMMUNICATORINFO command
Checks whether the Communicator for BricsCAD® add-on is correctly installed and provides a diagnostic report.
Note: The command is available on Windows only.
Until V21, the major versions of BricsCAD® and Communicator for BricsCAD® should match (for example: Communicator for BricsCAD® V20.2.x works with BricsCAD® V20.2.x).
Starting with V21 the compatibility between minor releases is supported (for example:Communicator for BricsCAD® V21.1.x will work with BricsCAD® V21.2.x).
Switches to the Prompt History window and then provides a report.
When Communicator for BricsCAD® is not installed, then the command reports:
Brief check result: Communicator module loading: FAILED
