Communicator for BricsCAD - Getting started
Communicator for BricsCAD is an optional plugin for Pro and higher license levels of BricsCAD that imports and exports 3D data between major CAD formats. Its high-quality conversions facilitate the re-use of 3D CAD data to improve productivity and reduce project costs.
Activating Communicator for BricsCAD
After you have installed Communicator for BricsCAD on your computer, you need to activate the software.
- Launch the LICENSEMANAGER command.The Bricsys License Manager dialog box displays.
- Next to Communicator for BricsCAD, click Manage License.
- The dialog box displays.
- Click Activate Trial to activate Communicator for BricsCAD trial license online.
- Click Activate Now…. You can:
- Type a valid Communicator for BricsCAD license key into the License Key field if you are using a Single User or Volume license.
- Type the Server name or local IP address of the license server if you are using a Network license.
- Click the OK button.
The license is registered, and a confirmation dialog box displays.
- Read the text on the dialog box and click the I understand button.
Note:
- To activate Communicator for BricsCAD license offline see: Offline/manual activation (Trial) or Offline/manual activation (Single/Volume license).
- To activate Communicator for BricsCAD network license on the license server see: Online activation (Network license) or Offline/manual activation (Network license).
