CONVTOSOLID command
Converts entities to solid entities.
Converts valid 2D and 3D entities to 3D Solid entities. Valid entities include:
  • Watertight 3D Mesh
  • Watertight 3D Surface
  • 3D Polygon Mesh
  • 3D Polyface Mesh
  • Circle with thickness
  • Closed Polyline of non-zero thickness and uniform width
Method
Select a valid entity then select another valid entity or press Enter to complete the command.
Note: The BIM data and GUID are maintained after converting.
