SMOOTHMESHCONVERT system variable
Mesh conversion mode
Controls the conversion mode of meshes to 3D solids or surfaces, with the CONVTOSOLID or CONVTOSURFACE commands.
| Type: | Short |
| Saved in: | Not saved |
| Range: |
1 to 3 |
| Default value: |
2 |
| Possible options: |
1: Conversion result is smooth and not optimized 2: Conversion result is faceted and optimized 3: Conversion result is faceted and not optimized |
