CONVTOMESH command
Converts entities to mesh entities.
Converts valid 2D and 3D entities to Mesh entities. Valid entities include:
- 3D Solid
- Surface
- Polygon Mesh
- Region
- Closed Polyline
Method
Select a valid entity then select another valid entity or press Enter to complete the command.
Note:
- The BIM data and GUID are maintained after converting.
- The value of the FACETRES system variable influences the display resolution of a mesh.
