DMFILLET command
Creates a smooth fillet between adjacent faces sharing a sharp edge.
Icon:
Creates constant or variable radius fillets between adjacent faces that are sharing a sharp edge. After selecting the edges, you can choose to specify a constant radius to fillet edges or one of the available advanced options.
The fillet is applied dynamically and the manipulator is displayed.
Note: When the CREATESKETCHFEATURE system variable is ON and only for default Constant radius mode, fillet features are created and are visible in the Mechanical Browser panel. The Radius property can be modified, but only valid values will be accepted.
Options within the command
- Variable radius mode
Allows you to create a variable fillet between adjacent faces that share (a) sharp edge(s) by specifying the two end radii.
Note: This option is available only for smoothly connected not cyclical edges.
- Intermediate radius mode
- Allows you to insert intermediate radii by picking points along the selected edges, after specifying a constant radius.
