GEOMAPMODE command
Reports the online maps style.
Reports the online maps style used in the current viewport.
Note: You can change the map style with the GEOMAP command.
| Reported value |
0.: Online maps are not displayed. 1.: The online maps style is set to bing Aerial. 2.: The online maps style is set to bing Road. 3.: The online maps style is set to bing Hybrid. 4.: The online maps style is set to esri Imagery. 5.: The online maps style is set to open street Map. 6.: The online maps style is set to esri Streets. 7.: The online maps style is set to esri Light. 8.: The online maps style is set to esri Dark. |
