LANDXMLEXPORT command
Exports Civil entities to a LandXML file.
Icon:
Allows you to select the BricsCAD Civil entities (Civil points, TIN surfaces, Horizontal Alignments and 3D Alignments, Strings) you want to export to a LandXML file.
Opens the Export To LandXML dialog box.
Select all
When checked, all entities in the drawing are selected for export.
Select objects in drawing
Click the select icon (
) to temporarily dismiss the Export To LandXML dialog box and select entities in the drawing to export.
Export
Opens the Save LandXML file dialog box where you can specify the location and name of the output LandXML file.
