LAYERSPANELCLOSE command
Closes the Layers panel.
Closes the Layers panel to hide it from the current workspace. If the Layers panel is stacked when you close it, the Layers tab or icon is removed from the stack.
LAYERSPANELCLOSE command - BricsCAD Lite & Pro | Bricsys Help Center
