LAYOUTMERGE command (Express Tools)
Merges entities from specified layouts into a destination layout.
Icon:
Method
Opens the Select Layouts to merge dialog box that allows you to merge entities from specified layouts into a destination layout, saving the corresponding views.
- Layouts to merge
- Destination layout
- Type a layout name
Layouts to merge
Allows you to choose one or more layouts to be merged.
Destination layout
Allows you select a destination layout from the list.
Type a layout name
Allows you to type a layout name. If the layout does not exist, the Create layout? dialog box opens which asks you if you want to create the layout or not.
Options within the command
- Remove empty layouts?
- Allows you to choose to delete empty layouts or not.
