LAYOUT command
Creates, copies, renames, and deletes layouts.
Icon:
Method
You can create an unlimited number of layouts in a single drawing. Each layout represents a sheet of paper.
Options within the command
? to list
Lists the names of layouts already defined in the drawing.
Set
Switches to the specified layout.
New
Creates new layouts.
Copy
Creates a new layout by making a copy of an existing layout.
Delete
Erases layouts from the drawing.
Rename
Renames layouts.
SAve
Saves the mentioned layout as DWG or DXF files format.
Template
Imports layouts from DWG, DWF or DXF drawing files.
Specify the file name and the layout names.
neXt
Displays the next layout.
Previous
Displays the previous layout.
