LCONNECT command
Creates or modifies an L-connection between solids.
Icon:
Creates or modifies an L-connection between solids. Optionally disconnects L-connected solids.
Before After
Options within the command
Select entities to connect
Manually select the two entities you want to connect.
Switch
Allows to choose between two butted L-connections:
or
or a mitered L-connection:
or a touching (disconnected) connection:
Note: If the HOTKEYASSISTANT is set ON, press Ctrl key to cycle between the connection types.
