LOOKFROM command
Turns the LookFrom view control on or off.
Icon:
Alias: NAVVCUBE
Changes the display of the LookFrom control between on and off, and accesses the settings for displaying the navigation control.
The LookFrom control dynamically adapts to the available drawing area or current viewport to maximize workspace. Depending on the size of the BricsCAD window and the drawing area, the LookFrom control is displayed as follows:
- In a large drawing area, the cube and compass are displayed.
- In a smaller drawing area, only the cube is displayed.
- In a very small drawing area, the LookFrom control is hidden.
The display changes automatically as the available drawing area changes.
Options within the command
- ON
- Turns on the display of the LookFrom control.
- OFf
- Turns off the display of the LookFrom control.
- Settings
- Opens the Settings dialog box at the LookFrom section, where you can view and modify the related system variables.
