MOVEBAK command (Express Tools)
Sets the destination folder for backup files.
Icon:
Method
Specify a new folder name for all .bak files.
Note:
- Enter a . (dot) to clear the MOVEBAK folder name. New .bak files will be created in the original folder.
- Type ~ to open the Select Folder dialog box, which allows you to select the MOVEBAK directory.
- The creation of backup files is controlled by ISAVEBAK system variable.
