MOVEBAK command (Express Tools)
Sets the destination folder for backup files.
Icon:
Method
Specify a new folder name for all BAK files.
Note:
  • Enter a . (dot) to clear the MOVEBAK folder name. New BAK files will be created in the original folder.
  • Type ~ to open the Select Folder dialog box, which allows you to select the MOVEBAK directory.
  • The creation of backup files is controlled by ISAVEBAK system variable.
