OBJECTSCALE command
Adds or removes scale factors.
Icon:
Adds or removes scale factors used with annotative entities through Annotation Object Scale dialog box.
Note: Annotative scaling adjust scale factors of annotative items, such as text and hatch patterns, to match the plot scale.
The Annotation Object Scale dialog box allows you to add or remove scale factors used with annotative entities.
- Object Scale List
- Options
Object Scale List
Shows all the scales supported by the selected annotative objects.
- Add
- Adds annotation scale factors to the selected entities.
- Delete
Removes annotation scales from the selected entities. Choose No in the Annotative field on the Properties Bar to remove the annotative property.
Note: This option does not work if there is just one scale factor attached to the entities.
Options
- List all scales for selected objects
- Lists all the scale factors.
- List scales common to all selected objects only
Lists only the scale factor shared by the selected entities.
Note: At least two entities must be selected.
