-POINTCLOUDEXPORT command
Exports the visible parts of a point cloud via Command line.
Method
Specify the export format. Then, insert the full path, file name, and the corresponding extension for the exported point cloud file.
Options within the command
- Specify the export format
 - Allows you to choose the export format.
