PARAMETRICOFFSETEDIT command (Experimental)
Edits an existing offset operation.
Alias: POFFSETEDIT
Disclaimer
Parametric Offset is an experimental feature which may not yet be stable, and could be removed in the future. Use the MANAGEEXPERIMENTALFEATURES command to enable or disable experimental features.
The Experimental mode is disabled by default. Enabling or disabling the Experimental mode requires a restart of BricsCAD.
Method
Enter the name of the desired offset operation, then select the parametric operation data to be edited.
Note: To dynamically edit an offset operation within a parametric block, select the block and drag the operation's grip point.
Options within the command
- Shownames
- Lists the names of all the offset operations available in the drawing.
- selection options (?)
- Lets you change the selection set of the specified operation.
Note: All editing options can also be accessed from the operation's right-click context menu in the Parameters Manager and Mechanical Browser panels.
