PCNEAREST command
Toggles the Point Cloud Nearest Point entity snap.
Toggles the Point Cloud Nearest Point entity snap to enable or disable snapping to point cloud nearest point.
You can launch this command at the Command prompt to toggle a running entity snap. Doing so changes the value of the 3DOSMODE system variable accordingly.
You can also launch this command within another command to turn off the entity snap only for the current operation. This does not change the value of the 3DOSMODE system variable.
