PCNEAREST command
Snaps point to nearest point of a point cloud.
Icon:
Turns on or off the Point Clouds Nearest Point entity snap to activate or deactivate snapping to nearest point of a point cloud.
You can launch this command at the Command line to turn on or off a running entity snap. Doing so changes the value of the 3DOSMODE system variable accordingly.
You can also launch this command within another command to turn off the entity snap only for the current operation. This does not change the value of the 3DOSMODE system variable.
