PEDITEXT command
Edits vertices and segments of a polyline.
Icons:
Edits vertices and segments of a polyline interactively, without first selecting the polyline.
Note: This command was meant for use with the Quad cursor. See more information in the Editing polylines article, under the Using the edit polyline segments tools in the Quad section.
Options within the command
- Add vertex
- Adds a vertex to the selected segment.
- add vertex at the End
- Adds a new vertex at the end of the polyline.
- adjust Bulge
- Modifies the bulge factor of the selected segment.
- Remove segment
- Deletes the selected segment.
- remove vertex (D)
- Removes a vertex. Activate the vertex by moving the cursor near the desired end of the segment.Note: A red dot will mark the active vertex.
- Stretch segment
- Moves the selected segment.
- Stretch Vertex
- Moves the selected vertex.
