PLAN command
Displays the plan viewpoint of drawings.
Icon:
Shows the 3D model in plan view which looks straight down on the x,y-plane.
Options within the command
UCS
Displays the plan view of a named UCS or Dynamic UCS after entering a name or placing the cursor over a 3D solid.
Note: To be able to run this command the second way, make sure that the UCSDETECT system variable is turned On.
Lists the names of UCSs in the current drawing.
World
Displays the plan view of the World Coordinate System.
Current
Displays the plan view of the current UCS.
