UCSDETECT system variable
UCS detect
Controls the dynamic UCS behavior. Dynamic UCS is a temporary UCS that activates automatically when the cursor hovers over a face, region or 2D entity.
A negative value is the same as 0, but helps in storing the earlier value.
Type: | Short |
Saved in: | Registry |
Range: |
-3 to 3 |
Default value: |
1 |
Possible options: |
negative: Disable dynamic UCS 1: Enable for faces of 3D solid and regions 2: Enable for 2D entities |
